Matty513 Posted May 8, 2017 Report Share Posted May 8, 2017 Alright so I have a level 6 18 and want to run it sub up in a trunk car. How tall would my enclosure need to be for the vents on the bottom of the motor need to be to function properly and not choke the shit out of the sub? I know the mounting depth is 13 inches but how much more clearance would it need beyond that. Thanks.in case it matters the car is an 03 accord coupe with pretty decent electrical but at the moment it'll only be seeing a sundown scv3k but I will remedy that shortly. Quote Link to comment Share on other sites More sharing options...
Matty513 Posted May 9, 2017 Author Report Share Posted May 9, 2017 Bump Quote Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted May 9, 2017 Report Share Posted May 9, 2017 I would try to have at least 2 inches clearance. Quote 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Matty513 Posted May 9, 2017 Author Report Share Posted May 9, 2017 Thanks man. Quote Link to comment Share on other sites More sharing options...
