6 15s 4th Order - DC Audio, Skyhigh 03 Explorer(Updated pg 3)
Surprised you were only rising 2X.  Also, that DD should take 1/2 ohm no problem.  Either way, it looks good man, keep at it!
IG @walledsonic
  • 1 month later...
Small update
Sold some of the V2 to get try to get all V1.
Worked on the battery rack and amp rack. Trying to play around with ideas and I like the approach its going now. Basically the amps will be screwed into a piece of wood that is jigsaw out that you only barely see any wood expect where the screws will mount. Then that same piece of wood is kreg jig into a bottom piece. 3 amps on top and 3 amps on the bottom. I will be running them strapped each pair @ 1ohm(.5 per amp). I am still trying to figure out to do with the middle piece though. I am ordering a custom light from low notes garage and I want it to go between the amps so I will figure out something soon for them. The link bars should be here soon as I can get started on wiring very soon and ordered a cockbox. Anyways enough babbling lol
Got 6 in for looks purpose
I did order my custom glass piece from Brent Leavitt. I did decide to cut the middle boards between the amps back to the same width as the bottom piece but leave a gap in the middle that will stick out for the glass piece to mount on...hard to explain but will look like this
Waiting on the link bars but will start measuring out he holes that will go for the amp inputs this weekend hopefully
  • 1 month later...
  • Who's Online   2 Members, 0 Anonymous, 1537 Guests (See full list)
