olumpa Posted May 14, 2017 Report Share Posted May 14, 2017 I have these 2 M2c amps, I am unable to use the link mode the Main amp puts out double the power of the Link amp. Here is the pic of the amps. Does anyone have any ideas why this is the case? Also I gain matched the amps but the crossovers I was unable to get them matched by voltage. Link to comment Share on other sites More sharing options...
bolanorthhighlands Posted May 14, 2017 Report Share Posted May 14, 2017 It looks like two different amps My 2002 Kia Spectra LS My YouTube Channel Link to comment Share on other sites More sharing options...
olumpa Posted May 14, 2017 Author Report Share Posted May 14, 2017 They are both m2c amps but when I try to set the crossovers the slope seems different, and when in Link or strap the voltage out on the non main amp is half . Did DD make multiple versions of this amp? Link to comment Share on other sites More sharing options...
mbdblue Posted May 14, 2017 Report Share Posted May 14, 2017 I would put a call or email in to DD and find out if they changed anything besides the logos....what are the numbers you're getting? and which are you using as your main? AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
olumpa Posted May 14, 2017 Author Report Share Posted May 14, 2017 Yea im going to call DD in the morning. We set the gains by playing 60hz (did it at night, low volume) have not done a full tilt test yet. I was trying to use the newer one as the main I think I will try the older one as the main . When I had the single amp I clamp tested it at 2606rms at 1 ohms. I hope for more at .5 ohms Link to comment Share on other sites More sharing options...
Ron36 Posted May 15, 2017 Report Share Posted May 15, 2017 Those amps have to be different even if it's minor there's something different not letting them link. Find a match for one of them it's never hard selling a DD amp. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
olumpa Posted May 15, 2017 Author Report Share Posted May 15, 2017 I figured that linking them would be very simple or even crossover /gain matching everything would be easy. Maybe when I talk with DD they have more info on what is different about them. I have them gain matched and I have the crossovers turned all the way up, subsonic all the way down and a signal processor set to 60hz low pass subsonic at 20hz. Is there any reason this setup would not be good? Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted May 15, 2017 Report Share Posted May 15, 2017 I wouldn't link them anyway. Gain match all day long. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
olumpa Posted May 17, 2017 Author Report Share Posted May 17, 2017 That's what I ended up doing, DD did not have a reason why Link isn't working so... I am going to get a DSP and set the crossovers on that. So far I am very happy with the amps. Just need more power behind the amps. Link to comment Share on other sites More sharing options...
