Here is a question for your question:
If you played a 10hz square wave vs sine wave into your sub, which one would produce more heat?
Pioneer 80PRS
There is more energy under a square wave than a sine wave of the same amplitude.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
Ok so I am just trying to figure out where the logic for #1 comes from and where it went wrong. A sub coil is cooled by its movement, and moving less would cause more heat, along with more "power under the curve" causing more power to be disapated which can be hard on a coil. So at some high power level and low frequency that would lead us to believe that #1 is true?
Pioneer 80PRS
I felt like it was more of a "which is more relevant" type question
He said, clipping can damage speakers but why? Imho, it comes down to which is more likely to blow speakers, square waves or overpowering? I can't really blame square waves as plenty of electronic/modern music use it.
A true square wave would contain twice the energy as a sine wave of the same amplitude (.707^2 = .5).  This would be an excellent place to employ #5.
Hypothesis:  A Square Wave with the same energy as a Sine Wave would generate more heat when reproduced by a speaker.
Sure square waves exist in recorded music but it is over the whole spectrum mixed with a multitude of other waves. The real question is when a driver has to reproduce a signal that is in a very narrow band and the signal is a very low frequency and it is clipped from the source, like the head unit is maxed out. What happens then? Sorry if I assumed the original question was aimed at the subwoofer usage. This is where people are most likely to run into problems.
Pioneer 80PRS
A subwoofer is a speaker - everything applies.
  • Like (+1 Rep) 2
Signal compression, the amplifier is still doing its job untill you hit hard clipping. As noted above, square waves have more energy vs a sine regardless of source however, you are much more likely to blow a speaker by clipping it with x2 the rated power vs clipping it at its rated power. Its like the old saying, all clipping is distortion but not all distortion is clipping.
*No need to apologize, we are all here to better our engineering skills and for as long as I've been installing i still learn a thing or two at smd everytime.  I appreciate everyone that's willing to teach/learn.
Edited by slowfkncar
 Share
