Amp going into protect
graham0599
So I know there's a millions threads about this topic but I feel this case is a little different, at least from what I've been able to find. What I have is a Formula-X 5k. It's wired at 1ohm, gains set at -5db with DD-1. T-Spec V12 rca from Pioneer AVH-X4500BT to PAC LC-1. Same rca from LC-1 to amp. AudioTechnix "1/0", throwback to before AT became CT lol, also the wire is actually a 2/0. 2 pos, 2 neg runs from amp to rear batts. Each run is about 3' each.
The amp is randomly going into protect and I can't figure out why. It will do it at any volume, any temperature, any voltage, just totally random. It seems to do it the first time after like 20+ minutes of just low/average volume listening. It'll stay off probably 2-15ish mins, come back on, then after probably 10-15ish mans, shut back off, and repeat. Amp rarely sees below 14v. At full tilt, it rarely sees below 13v. Amp gets plenty of air flow since it's raised and very open, A/C blows on it too. It's hardly warm when it happens, barely above car temp.
The one thing I'm wondering if is affecting is, is the LC-1. I don't know if they can "wear out" mine is around 3 years old. I'd prefer to not bypass it but I could temporarily for testing
link to amp http://www.caraudioclassifieds.org/forum/#/topics/202569?page=1
Thanks for any help
Let me know if I missed anything/any questions
Is your alt spiking? I have a teammate whose amp would shut off randomly and turns out the alt was momentarily spiking to 15-16v throwing the amp into over voltage protect. And would almost happen fast enough where the indash volt meter (OEM) wouldnt show movement nor would the stinger vm sometimes.
Try different RCA's and without the PAC, I'd try that first and see how it effects it
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I don't know how to check if the alt is spiking, maybe I could wire in a temp. analog voltage meter
The RCA's are nearly brand new but I guess it doesn't hurt to try. I'll try pulling the LC-1 this week.
I'm just hoping it's not something internal with the amp
  • Who's Online   1 Member, 0 Anonymous, 236 Guests (See full list)
