Possible to use two resistors in series to drop voltage out of HU?
L5hunter
A while back, I posted a thread about ways to use an amp with a maximum of 2 volts gain amp with a modern 4v head unit. It occurred to me today that I could simply use one of the most basic electronic circuits ever: two resistors in series to drop the 4v RCA preout to a 2v one. Would this work in practice? I can't think of a reason it wouldn't, but I figured I'd ask anyway.
The process I would use is detailed here: http://www.learningaboutelectronics.com/Articles/How-to-reduce-voltage-with-resistors.php
Current "budget" setup
Car: 2001 Ford Focus ZX3 bone stock other than some pimpin wheels.
Head Unit: Alpine CDA-117
Amp: JL 1200/1v3
Subs: JL 13W7AE
6.5s: MBQuart ONX 116
5.25s: Orion Cobalt CO500
SQ build (in progress):
Car: 2005 Dodge Ram 3500 Quad Cab
Head Unit: DEH-80PRS
Amps: ???
Subs: ???
6.5s: 2 HAT Legatia L6s
5.25: 2 HAT Imagine 5.25 Coaxials
In other words, the exact opposite of a line driver.
Amp: JL 1200/1v3
Subs: JL 13W7AE
Amps: ???
Subs: ???
You could use resistors, but you could also not turn the volume up so much. Chances are that the 4v head unit doesn't actually put out 4v.
Pioneer 80PRS
This was the consensus the last time I asked as well. Unfortunately, that would mean if I had another normal 4v amp, the volumes wouldn't match unless I changed the gain in that one to 2v as well. Plus, It would be kind of dumb to only be able to turn up my stereo a little past half.
5 hours ago, Ahmed Johnson said:
Just don't turn up the gain. Have you checked the voltage coming out of your RCA'S to know what the voltage is?
Nope, this is all in theory at this point. I'll probably be quite surprised, I'm sure the combination of an output slightly under 4V and some long RCAs would bring it down to a manageable amount.
Amp: JL 1200/1v3
Subs: JL 13W7AE
Amps: ???
Subs: ???
You find where you head unit hits 2V, set your gain there (new max volume). And then if you get a amp that has gain down to 4v, all you would have is the gain higher than normal and you would be good to go. You are way overthinking this.
What amp are you using, out of curiosity?
IG @walledsonic
No one particular amp. I have several older Rockfords, Phoenix Gold, etc.
Amp: JL 1200/1v3
Subs: JL 13W7AE
Amps: ???
Subs: ???
Well this hypothesis makes for a good experiment. Grab your DMM and report back. Mmkay?
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 1343 Guests (See full list)
