Power tweeters from crossover
I'm kind of new to car audio and I can't seem to figure this out. If you are using a crossover or DSP how do you get power to your tweeters? I don't know any amplifiers that have that low of wattage except 4-channel amps. But then they only have 2 outputs, show what do I do with the other 2 channels?
Add more speakers.
I have a small 2 channel for my tweets.
IG @walledsonic
If you are using a crossover it matters whether you are talking an active or passive crossover. A passive crossover is probably want you want to start out with, these come with your component set and it means you can wire the mid and the tweeter to one active crossover and hook it up to 1 channel of the amp. So potentially you could run (2) component sets up front with included passive crossover and hook them full range to a full range 4 channel amp and then run (2) coaxial speakers in the back for rear fill.
Most setups run (1) 4 channel amp [Full range] and (1) sub amp [low range/sub frequencies]
  • Who's Online   2 Members, 0 Anonymous, 1662 Guests (See full list)
