6 minutes ago, Joe f said:
Thanks man, I'm going to go do some adjustments and I will let y'all know. The sa8s sounded really good so I didn't think about making any changes for the 15.
If your ssf was all the way up with the sa-8's then that zv3 will KILL the lows compared to the 8's.
OK so I adjusted the ssf and it helped some but I didn't play the sub enough to get it really warmed up to see if it will loosen up and play the lows better. The mid bass is very loud though. I'm sure if I had this same set up in a SUV it would be killing lows lol.
You want "SSF" (infrasonic filter) about 1/2 octave below tuning.  if you KNOW you're tuned to around 32.5 then set filter to 25-28 as a starting point and see if subs bottom out etc.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
OK so I got in some play time with the sub and did some adjusting on my amp and it sounds better but what I have came to realize is that I simply do not have enough power for this 15" sub. The sundown sae1200 worked really good pushing the 4 sa v1.5 subs and I expected it to push the zv3 15 enough to equal or surpass the loudness of the 8's but it just isn't enough power. I did change the tune down to 30hz and it now has the bottom end lows that I was looking for and I think it had something to do with it being in such a small area of my reg cab Dodge ram. Thanks for everyone's help and this is a great site for information and technical support, thanks again
