6th order bandpass ratios?
dylan117
Fact.  Im at like 5 cu ft for a 12".  Lol.  Its not a clean S10 with 2 18s on 10K or nothing, but ya know.
IG @walledsonic
11 minutes ago, Kyblack76 said:
Oh.... and,  I hate "what ratio" is best almost as much as "how much port area per cube"  ...  Hate that shit.
This x 1,000,000
Builds:
1 hour ago, rocking.that.eclipse said:
There have been a couple parallel tuned that I really like
But with that being said I have built 3 different series tuned and they all seem to play just fine. I think that I will stick to 4ths tho. Easier and just as much output in my opinion
they can work for us. Just not the best option IMO. I hate having two exit ports, can cause some funky loading/cabin pressurization.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
54 minutes ago, Kyblack76 said:
A "small" 6th order ...... phrase just sounds funny lol. Space eating mothers ...
I have a "small" 6th order...ratio wise it's only 1.35:1 but is 45 cubes gross Lol
2000 Suburban 6 runs of 2/0
12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door
8 banks of blue Maxwells + 260ah of Yin Long LTOs
2 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
161.6@38hz DBdrag  sealed on the dash… 162.54 outlaw…161.14 Meca headrest
4 hours ago, WalledSonic said:
Low tuning, smaller volume @Raptorman? Is that right? Thought low tuning would have a larger volume. Simulations on WinISD seem to favor a large volume for the low side, but i dont have a sickkk low tuned sixth like yourself, either :-P
Low tuning smaller volume rear chamber, large front chamber tuned high would be what a series tuned 6th would require.
WinISD does not simulate series tuned 6ths, it only does parallel tuned 6ths.
4 hours ago, Raptorman said:
It's right.
And pay ZERO attention to the graphs in winisd or any other program. They are utterly useless. All you should use winisd for is vent mach and tuning.
if you are referring to using winisd to design a series tuned 6th, then yes, the graph is useless.  But if you are using it to design a parallel tuned 6th, it's actually quite accurate, I have quite a bit of testing to back it up.
This has been covered already.
Post 'em up man. Would love to see the graph vs real world response! :)
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Just realized it was covered and was about to edit my post but you were too quick hahaha.
I had them posted but photobucket had to go fuck things up, i still have like 20 pages of photos in my current build thread to fix and would need to go though those old threads and fix them to share the data again too lol.  i'll get around to it eventually lol
I'd also like to point out that port area of the rear chamber definitely has an effect on output in a series tuned 6th.  I have data showing quite significant gains from increasing port area of the rear chamber while maintaining the same tuning frequency and volumes.  I'll see if i can find the post.
EDIT: doesn't look like I ever posted the result of adding port area. I'll have to dig through my notebook and see if i can find it at some point.
Yes it does. I have tons of notes as well testing 20-50 at the headrest with windows down for every change ive made to my 6th.
I have yet to see Winisd model up an accurate graph for any enclosure that I have designed/built. (I've designed over 3,000 enclosures alone)
Ported doesn't get as low as it says, it doesn't spike as hard as it says. It doesn't extend into the upper frequencies in a flat response as much as it says. It doesn't account for cabin gain, stiffness of panels within the vehicle, port areas, window configurations, box positions, etc.
4th bandpasses are especially hilarious because a 4th that plays 20-60 completely flat in the real world has a huge freaking spike at tuning with virtually no bandwidth.
Those graphs crack me up lol
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
