5 hours ago, bcbrassard said:
What happened?
I needed the engine for this;
I have that car for almost 5years now so thought it was time to put an engine in..
Plus the Golf mk3 was shit, rust and water leaks everywhere
  • 1 month later...
So the problem with the engine is fixed, only too almost a year ?
But the engine bay is complete now
Looked like this before
Painted and replaced a lot of stuff, while i was at it did the big 3
And the plans for the audio changed a bit.. again...?
The new plan(setup) will be as following:
HU: Pioneer MVH-X560BT
Sub: Rockford Fosgate Power T0D215
Sub Amp: Rockford Fosgate Power T2500.1
Mids and Highs: Rockford Fosgate Punch P1652-S Components
Mids and Highs Amp: Rockford Fosgate Punch P200.2
Electrical:
Ground Zero GZBP 12.3500X battery
Stock 90 Amp Alternator
CCA 0 awg power/ground/big 3
CCA 8 awg subwoofer wire
CCA 12 awg speaker wire
Hollywood Energetic RCA's
Hollywood Energetic Fuses and fuseholders
Rockford Fosgate PEQ remote controller
The Punch components, if they're not loud enough for with the T0 15 i will upgrade to T2 components and T400.2 amp
Trying to set the amps temporarily, until i bring it to a shop (i'm a noob)
The T2500 is set at 40hz and the gain at 3
And the P200 at 70hz all pass and the gain at 6
Will this be ok/safe until i bring it to a shop to tune?
Thanks !
if you're waiting for a shop to tune, I would go ahead and leave the gain at 0 on both. as for the T2500 being set at 40hz, is that for the LPF or HPF? I'm assuming LPF, in which case, I would say no lower than 80, unless your mids can play 80hz well
  • Who's Online   0 Members, 0 Anonymous, 1234 Guests (See full list)
