(3) SA-10D2 REV2 underpowered with CT SOunds 1400.d?
Pope DaHammer
I am wondering should i get a bigger amp?  I am running 1.33 ohms with the CT SOUNDS 1400d on  (3) SA-10D2 REV2's Ported.    Now i saw Steve Dyno this amp and it does 2400 or better dynamic @ 1 ohm.   the subs are rated at 750 watts RMS.  So at 1.33 ohm it pounds.  But i am wondering  will a bigger AMP push them harder or am i good where i am?
If you think I can go with a stronger AMP...what would you suggest.  Money is really no object.
You need a bigger amp. Your trying to run 1400rms to 2250rms with of subs... You need at least at 3k+ for those. Especially at 1.33 instead of 1.... those can handle a good 1200-1500 clean each...
05 TL build log SOLD
Got the same subs I'm running a American Bass VFL 120 witch is 2200rms at 1ohm, I'm running at .6ohms so getting around 1k per sub and they take it allday. Would get a bigger amp.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
A 1400w amp divided by 3 subs is less than 500w each. Especially if you are running over 1 ohm. You might be less than 350w each with impedance rise so you should be able to get a lot more out of them.
I would get two more amps and run one on each sub and Wang the heck out of them.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 945 Guests (See full list)
