Hi,
I purchased a OM-1 a few months ago. Now I installed it and it runs... a sort of. I cant adjust the sensitivity low enough. My amp does 107V before Clipping (According to DD-1+) and the OM-1 should be capable of 150V.
Also, wenn I run my system my amp will protect at roughly 70% of volume when the OM-1 is connected. Under 70% it works like it should.
Is this a known issue or do I have a bad OM-1?
On 8/1/2017 at 0:16 PM, piti_rocks said:
Hi,
The sensitivity adjustment of the OM-1 should allow it to be used on amplifiers from 12V - 150VAC output.  Is this a class D subwoofer amplifier that you are having the problem with?
This is a forum. Have you tried emailing them or picking up a phone and calling? This is not their business site. This is just a bunch of bassheads talking. I'm sure if you were to call that Tony would walk you through it step by step.
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
how can you be sure that your amp isnt producing distortion? Have you looked at the output on an o-scope to confirm you have a clean signal?
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1240 Guests (See full list)
