2015 Chevy Sonic/Wall/4 15's/10K/Lithium/Large Case Hairpin US Alts
So everything is stained with 2 coats on all visible faces and a single coat for any back-side areas.  Glue lines wont soak up stain really well on a single layer of stain.
Glue lines get covered up pretty good after a second stain though.
Also laid a single coat of satin clear last night.  Its easy to think that you've stained it too dark.  But the application of the clear urethane is where the magic happens.  Here's the spread today:
So on the first coating of urethane, you may have a lot of fibers causing roughness.
...and it may look OK in some lighting, but this is unacceptable after spending so much time already
A sanding block is nice, it really helps knock off the high spots without gouging the part
After a wipe down, it doesnt seem like much has happened, but it feels super smooth.  Also, I didnt sand through the clear and into the stain, just scuffed the high spots off the urethane layer
Great products, highly recommended
So for the second and third coats, I recommend wiping down with a cloth instead of using a brush.
I'll follow thru with second and third coats of clear to show off how much it brings the color back out of the wood after its been stained heavily
IG @walledsonic
After sanding and second coat of clear:
After sanding and a third coat of clear:
And after another sand and a FOURTH coat of clear.  Like candy
Then threw a fresh coat of white in the trunk until I figure out exactly what Im doing with it
Mounted the lithium cooling fan with some sound foam
Battery cage:
Drying a fresh coat of clear in the sun smooths it out sooo well
Here's the spread with poor lighting
Neoprene foam on all contact points of the batteries to the cage
The batteries slip in the cage from the rear and this piece holds the batteries in
All together
The JY bus bars come loose without lock washers installed
Insulation to prevent air leaks.  I want all the air to flow thru the bank
Next up: a shit ton of cable cutting and crimping
IG @walledsonic
Loving that bank jy power goodness.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   1 Member, 0 Anonymous, 1583 Guests (See full list)
