Noah Lee Posted August 10, 2017 Report Share Posted August 10, 2017 HI this is is probably a frequently asked question and a newbie one but i have a single sundown sa8 and am wondering what differences there are between running the sub at 4 ohm vs 1 ohm and what power can i safely run a single sa8 at? any help will be greatly appreciated Link to comment Share on other sites More sharing options...
never knows best Posted August 10, 2017 Report Share Posted August 10, 2017 http://www.bcae1.com/ohm.htm Link to comment Share on other sites More sharing options...
06RTCharger Posted August 11, 2017 Report Share Posted August 11, 2017 Seems like for subs it usually just comes down trying to get the most power without blowing anything. Pretty much all amps have higher output when the ohms are lower rather than higher. So just make sure ur amp can run 1ohm safely and u have the electrical to support that larger electriccal draw. If im not mistaken an amp will draw more power when youre wired to a lower load/ohms. Just my noob views on the topic. Link to comment Share on other sites More sharing options...
8ten8 Posted August 11, 2017 Report Share Posted August 11, 2017 What Charger said^^^ Get the best the bang for your buck and wire down. What voice coil and what version? Assuming you have a D2 V2, with clean signal and clean power, I would feel comfortable running 700-900w after break in. That's just me thoe, I like to overpower a little Link to comment Share on other sites More sharing options...
