Diaz310 Posted August 12, 2017 Report Share Posted August 12, 2017 So I have a 2008 Toyota Yaris sedan base model I installed 2 JL audio amps the JX series 400 watts for voice and 1000 watts for bass and an audio control epicenter I have alpine type r components all around and a type R 10inch woofer. Also I installed an after market head unit a pioneer avh-270bt when I play louder then volume 15 and the sub knocks it cuts out and then there's no bass until I put the volume down. I got a couple opinions from friends and some said to put a capacitor or a stronger alternator. Because I installed an optima red top battery to see if that'll solve the problem but nope any help ? Link to comment Share on other sites More sharing options...
Ron36 Posted August 12, 2017 Report Share Posted August 12, 2017 Check your voltage when it cuts out might be so low the amp turns off. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
06RTCharger Posted August 13, 2017 Report Share Posted August 13, 2017 If its cutting at 15 out of 62? Does ur pioneer go up to 62? If it does, to me id assume ur gain nob on the amp is maxed out? Link to comment Share on other sites More sharing options...
Diaz310 Posted August 13, 2017 Author Report Share Posted August 13, 2017 12 hours ago, Ron36 said: Check your voltage when it cuts out might be so low the amp turns off. everything is set on low and it still does it Link to comment Share on other sites More sharing options...
Diaz310 Posted August 13, 2017 Author Report Share Posted August 13, 2017 2 hours ago, 06RTCharger said: If its cutting at 15 out of 62? Does ur pioneer go up to 62? If it does, to me id assume ur gain nob on the amp is maxed out? i believe it stops at 32 but ima check that out thanks Link to comment Share on other sites More sharing options...
