sencheezy Posted August 16, 2017 Report Share Posted August 16, 2017 High Voltage Lithium Initial thoughts and overview. 1 350 volt Michigan Solar Energy High Voltage lithium battery. 1 Taramps T60K wired at .5 Starting voltage: 307 Final Voltage drop: 266 ~220vac 92 amps output ~266vdc 82.7 amps output 92% efficient 20,000 watts rising to 2.4 ohms clamped. The battery FYI is 6ah. Cost between 3-5 grand. Weighs 60 pounds. And the amp is $1700. 307v is less than 20% charge. Battery is 1.8kwh. 1c rate is 1,800w for 1 hour 2c rate is 3,600w for 30 min 4c rate is 7,200w for 15 min So far, I'm extremely estatic about the results and the future possibilities using these technologies together. Just think, you can literally burp 20,000 watts, out the trunk of a BMW or smart car haha. Where this cost would be justifiable, would be for applications that requires a lot of power, low weight, and space savings. This battery is only 27"x17"x4". So the power density per space is truly unmatched. I will be posting more of my findings, so stay tuned. Also, you can add as many as you want in parallel to get some really stupid power levels. *BONUS* The excursion did a 157.x outlaw @ 41hz wit that 20k. So I'm really excited about that! Rayshawn Lawrence built the enclosure. 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy Link to comment Share on other sites More sharing options...
sencheezy Posted August 16, 2017 Author Report Share Posted August 16, 2017 Uploading a photo shouldn't be this difficult lmao 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy Link to comment Share on other sites More sharing options...
sencheezy Posted August 16, 2017 Author Report Share Posted August 16, 2017 [URL=https://goo.gl/photos/479zkEVBdipVRhDw9]https://goo.gl/photos/479zkEVBdipVRhDw9[/IMG][/URL] 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy Link to comment Share on other sites More sharing options...
sencheezy Posted August 17, 2017 Author Report Share Posted August 17, 2017 Well guys, I can't figure out how to share these pictures. Smh. 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy Link to comment Share on other sites More sharing options...
Charles Phillips Posted August 17, 2017 Report Share Posted August 17, 2017 Looking good man. Is there a lithium battery you'd suggest for a 5000W music daily driver? - 2009 Toyota Matrix Base - - iPad 64GB - - miniDSP 2x4 HD - - PPI Art a200.2 - - SoundQubed SQ-2200.2 x 2 - Link to comment Share on other sites More sharing options...
WalledSonic Posted August 17, 2017 Report Share Posted August 17, 2017 Link works bruh. Innovative setup! Looking forward to more info. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
sencheezy Posted August 17, 2017 Author Report Share Posted August 17, 2017 Yeah he can make any size. 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 18, 2017 Report Share Posted August 18, 2017 Fixed it. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 18, 2017 Report Share Posted August 18, 2017 Awesome stuff! How often do you have to charge it up? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
sencheezy Posted September 13, 2017 Author Report Share Posted September 13, 2017 https://youtu.be/i-Pz5kwQlVE 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy Link to comment Share on other sites More sharing options...
