Gutta Trash Posted September 5, 2017 Report Share Posted September 5, 2017 I'm currently deciding between a 1 ohm and 2 ohm version of the same amplifier. The to own seems better suited for my build but I have a question about rise. If I am running an amp at 1 ohm and rise to 5 ohms does that mean that if I run an amp at 2 ohms I would rise to six or seven ohms? Or would the rise stay the same. As you can imagine this would weigh my decision on which to go with. TIA On 4/20/2010 at 10:06 PM, 'cc_audio' said: Guys are just like girls, once you've had 18 inches you don't go back. 2004 GMC Yukon XL Pioneer AVH-X4700BS 13 band EQ Sub Amp- (2) PPI 5000BD.1 (2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz (4) 6.5 Bose Mids (2) 1" Bose Tweets (2) 1.5" Bose Tweets (1) JY 80 AH w/ new JY busses (1) Duracell 750 up front Apex Alternators 270 A.C. Delco 160 alternato Link to comment Share on other sites More sharing options...
WalledSonic Posted September 5, 2017 Report Share Posted September 5, 2017 Legitimate question. Check out this thread: Check out the second post for an answer to your question. The characteristic shape of the impedance curve stays relatively the same. If you are currently wired to 1ohm and rise to 5, then if you're wired to 2ohm you should rise to 10. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
WalledSonic Posted September 5, 2017 Report Share Posted September 5, 2017 What frequency are you rising to 5 at? I dont think you're rising that high across your frequency spectrum, it must be just at a few points/frequencies, right? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
