Another Stupid Question About Box Rise
Gutta Trash
I'm currently deciding between a 1 ohm and 2 ohm version of the same amplifier. The to own seems better suited for my build but I have a question about rise. If I am running an amp at 1 ohm and rise to 5 ohms does that mean that if I run an amp at 2 ohms I would rise to six or seven ohms? Or would the rise stay the same. As you can imagine this would weigh my decision on which to go with. TIA
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
Legitimate question.  Check out this thread:
Check out the second post for an answer to your question.  The characteristic shape of the impedance curve stays relatively the same.  If you are currently wired to 1ohm and rise to 5, then if you're wired to 2ohm you should rise to 10.
IG @walledsonic
What frequency are you rising to 5 at?  I dont think you're rising that high across your frequency spectrum, it must be just at a few points/frequencies, right?
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 565 Guests (See full list)
