3sixty.3 output voltage adjustment
I searched and found nothing or any reasoning behind it help please.  I plugged in a jumper rca to the output and tried to test the output voltage that goes to the amp but i am reading around .027 with the volume at its max undistorted level doesn't make sense.  I would like my output voltage to fall between the amp input of 0 to 4 volts but the channel level is in dbs.  How do i set this
Most amps are capable of taking up to 8v line voltage anyways, so if youre looking for 0-4v input, youre well within the limit of the amp. Having a higher line voltage will require you to adjust the gain less for undistorted signal reproduction/amplification, and should give you a lower noise floor.
And yes, line voltage is AC, not DC. Glad you figured your issue out, and now you know that info for the future.
  • Who's Online   1 Member, 0 Anonymous, 998 Guests (See full list)
