twalker182 Posted September 17, 2017 Report Share Posted September 17, 2017 Setup looks clean. I grew up on mini trucks....always loved Space Cabs. Upgrade those wheels and give that paint a good polish/wax and you're money. 2010 Accord Sedan XS D3400R Clarion HU Sundown mids and highs Incriminator amps Incriminator Lethal Injection 12" Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 17, 2017 Report Share Posted September 17, 2017 Welcome and nice build, click the following link for song info: https://www.stevemeadedesigns.com/board/forum/19-tunez-all-things-music-related/ 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
LOWrider Posted September 17, 2017 Author Report Share Posted September 17, 2017 45 minutes ago, twalker182 said: Setup looks clean. I grew up on mini trucks....always loved Space Cabs. Upgrade those wheels and give that paint a good polish/wax and you're money. Thanks! I'm looking around for wheels. Not the easiest to find either 15's (that was stock) or 17's (what I wouldn't mind putting on) that have a bolt pattern of 6x139.7. As far as paint goes, it has a little rust in some areas (it's almost 30 years old and spent the last 6 years in a field, I don't blame it), so I'm actually considering plastidipping it. Not just a couple of $5 cans from AutoZone, but like a $700 kit with a layer of pearlescent over it. Going to see how it all ends up going, but should have both of those accomplished before Thanksgiving. 48 minutes ago, ShadeTreeMechanic said: Welcome and nice build, click the following link for song info: https://www.stevemeadedesigns.com/board/forum/19-tunez-all-things-music-related/ Thanks and thanks again! I'll check it out, appreciate it. Link to comment Share on other sites More sharing options...
twalker182 Posted September 17, 2017 Report Share Posted September 17, 2017 Check your local Craigslist for Escalade or Tahoe wheels. 2010 Accord Sedan XS D3400R Clarion HU Sundown mids and highs Incriminator amps Incriminator Lethal Injection 12" Link to comment Share on other sites More sharing options...
LOWrider Posted September 17, 2017 Author Report Share Posted September 17, 2017 10 minutes ago, twalker182 said: Check your local Craigslist for Escalade or Tahoe wheels. Not a ton of options in the area, plus they're generally 20's when looking them up. But what I've found I like the most are Toyota TRD's. There are some nice ones in the area, but dropping $600 on rims is not super fun. Link to comment Share on other sites More sharing options...
SkarredSierra Posted September 17, 2017 Report Share Posted September 17, 2017 Its halloween time. Go get a furry mask from walmart. Link to comment Share on other sites More sharing options...
LOWrider Posted September 17, 2017 Author Report Share Posted September 17, 2017 49 minutes ago, mathewyocham said: Its halloween time. Go get a furry mask from walmart. Actually, not a bad idea haha Link to comment Share on other sites More sharing options...
tmacg12345 Posted September 17, 2017 Report Share Posted September 17, 2017 so a couple points.. typically the lower you tune the easier the subwoofers can physically match the amplitude of the signal given by the amp, so basically more excursion. more excursion = more air being pressurized inside your cabin = hair trick. HOWEVER.. the tuning of your box along with fs of speaker etc. will determine which freq your subwoofer/box is able to match that wave the best. long story short if your box is tuned to 40hz play a 40hz test tone and chuck some power to it to see what she does. if it doesn't hair trick you just need more power to get those things moving!!! btw 4000w on 4 15s walled should be enough for a baby hair trick. SHOULD be. welcome to the forums bud! Link to comment Share on other sites More sharing options...
06RTCharger Posted September 18, 2017 Report Share Posted September 18, 2017 I know theres a thread about songs that hit bass hard. Forget what its called. Theres a music area tho somewhere on the homepage Link to comment Share on other sites More sharing options...
LOWrider Posted September 18, 2017 Author Report Share Posted September 18, 2017 6 hours ago, tmacg12345 said: so a couple points.. typically the lower you tune the easier the subwoofers can physically match the amplitude of the signal given by the amp, so basically more excursion. more excursion = more air being pressurized inside your cabin = hair trick. HOWEVER.. the tuning of your box along with fs of speaker etc. will determine which freq your subwoofer/box is able to match that wave the best. long story short if your box is tuned to 40hz play a 40hz test tone and chuck some power to it to see what she does. if it doesn't hair trick you just need more power to get those things moving!!! btw 4000w on 4 15s walled should be enough for a baby hair trick. SHOULD be. welcome to the forums bud! I took your advice, grabbed my dad's old dB Drag disk to roll through frequencies, got it in the forties and cranked up the gain. Looks like I can do basically what you said- a baby hair trick. Appreciate the hospitality! 44 minutes ago, 06RTCharger said: I know theres a thread about songs that hit bass hard. Forget what its called. Theres a music area tho somewhere on the homepage I found the music area on the forums, gonna look around that for a bit. Thanks man. Link to comment Share on other sites More sharing options...
