Dragonware Posted October 19, 2017 Author Report Share Posted October 19, 2017 4 minutes ago, WalledSonic said: Ive also seen a two dope Passive Radiator setups recently. Saves on space big time bc you dont need port volume. Just space for the PR. after a quick google search you are basically suggesting a system that works like allowing a sealed enclosure to flex with one Subwoofer and just a cone and basket structure in the back to alow more movement of sealed air. Nice but I would not want to destroy a sub to try it. if glassing two pods with ports is alot of work id be fine with re building a single 12 ported to use less space. Since these are re coned how would I get the VAS, Xmas etc for the new configurations ? My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
WalledSonic Posted October 19, 2017 Report Share Posted October 19, 2017 SMD IM-SG. I have (4) PSI 15s and the TS specs they reported are not true. Testing is the only way to truly know Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
Dragonware Posted October 19, 2017 Author Report Share Posted October 19, 2017 5 minutes ago, WalledSonic said: SMD IM-SG. I have (4) PSI 15s and the TS specs they reported are not true. Testing is the only way to truly know wow thats $300 bucks i need to find someone with one I can use My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
06RTCharger Posted October 19, 2017 Report Share Posted October 19, 2017 Theres a tool map around here somewhere. Might be lucky and have someone in ur canada area that can loan/rent you a SMD IM-SG Link to comment Share on other sites More sharing options...
06RTCharger Posted October 19, 2017 Report Share Posted October 19, 2017 Lmao ummmm not sure u wanna say that right here.... Link to comment Share on other sites More sharing options...
Dragonware Posted October 19, 2017 Author Report Share Posted October 19, 2017 2 x 12 in a sealed would prob not be a bad option for me also My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
Wishuponasub Posted October 20, 2017 Report Share Posted October 20, 2017 12 hours ago, Dragonware said: 2 x 12 in a sealed would prob not be a bad option for me also This is true also. A proper sealed box can sound really good. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4 Link to comment Share on other sites More sharing options...
Dragonware Posted October 24, 2017 Author Report Share Posted October 24, 2017 do we have any professional box designers in here ? will compensate for your help My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
Dragonware Posted November 3, 2017 Author Report Share Posted November 3, 2017 can someone direct me to someone who can help me get some plans to build a new box ? Wedge style dual 12 sealed 2 cubes not sure how to calculate and design for the seat angle. Or single 12. simple slot port wedge tunned to like 32hz max width is 36 inch and max height is 14 inches depth of subs are 7 inches im sure im missing some values but thats why im asking for help. My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
06RTCharger Posted November 3, 2017 Report Share Posted November 3, 2017 Might wanna start a new thread. Post the sub you’ll be using, the amp you’ll be using and you’ll need to give more info on ur dimensions for that angled portion. Link to comment Share on other sites More sharing options...
