Mr. Clapp Posted November 8, 2017 Report Share Posted November 8, 2017 Any advice/recommendations are appreciated. Planning out a new system build for my 2001 Ford Escape. The new system will include two soundqubed 18's (HDC3s or HDC4s if I can find them for the right price) in a 12 cube ported box. For amps I'm either going to strap two CAB 1600s or just get a taramps 8K. My question is whether one XS Power d3400 will be enough (along with a d1200) or should I go for the d3100. I have a stock alternator (110 amps) without the big 3 upgrade with 0 gauge welding cable from front to back. Current system has a kicker KX 2400.1 (2600 watts rms) with a XS Power d1200. Link to comment Share on other sites More sharing options...
deathcards Posted November 8, 2017 Report Share Posted November 8, 2017 is this a dailly? skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
WalledSonic Posted November 8, 2017 Report Share Posted November 8, 2017 Needs much more electrical Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
deathcards Posted November 8, 2017 Report Share Posted November 8, 2017 2 minutes ago, WalledSonic said: Needs much more electrical tbh i couldn't agree more with this try a good brand h.o. alt 2-3 batteries in back with upgrade battery underhood and always watch voltage with that much power skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
WalledSonic Posted November 8, 2017 Report Share Posted November 8, 2017 I ran a 6K with a 240A singer alt and 395Ah of XS battery and I couldnt play full tilt at idle more than about 20seconds without needing to increase the RPMs. And I had rise that started at 1.3ohm. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
Mr. Clapp Posted November 8, 2017 Author Report Share Posted November 8, 2017 Voltage with my current setup rarely drops below 12 volt with everything turned up. I know that will change when i double or triple the power output. I'm trying to stay away from a H/O alternator and won't using the max potential of the amps I have. Plan on making a big system to use for a few months before I move off to college, afterwards everything will be removed. Link to comment Share on other sites More sharing options...
AlpineNut Posted November 8, 2017 Report Share Posted November 8, 2017 OK get these caps in the video as well that Steve himself uses and you know damn well he is pushing alot of power! 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n Link to comment Share on other sites More sharing options...
WalledSonic Posted November 8, 2017 Report Share Posted November 8, 2017 3 minutes ago, Jake Pace said: OK get these caps in the video as well that Steve himself uses and you know damn well he is pushing alot of power! LOL have you checked the cost of caps? Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic Link to comment Share on other sites More sharing options...
Mr. Clapp Posted November 8, 2017 Author Report Share Posted November 8, 2017 Out of my budget lol Link to comment Share on other sites More sharing options...
8ten8 Posted November 8, 2017 Report Share Posted November 8, 2017 At least do the big3. More reserve is good too. Check this thread out, it's a great read Link to comment Share on other sites More sharing options...
