** Best Ground Locations **
keep factory grounds. go to frame it you have one if not go to shock tower
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
you can tap it if you want, but not necessary. drill hole, clean area around hole to bare metal, place dielectric grease on clean area, attach lug to frame on greased area, bolt and nut into place.
  • 3 weeks later...
If your car has a frame, go to the frame front and rear
If it's a nobody, strut tower or other large load bearing piece part of the main body
  • Who's Online   1 Member, 0 Anonymous, 1227 Guests (See full list)
