Voltage drop
have u done the big 4?
Our u getting any belt slip?
Is it doing it under load?  ( ac, heat, system turned up)
What is your electrical like?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
IG @walledsonic
I do have the big 4 done ... electronics right now are two amps  one dc 90.4 and one dc 5 k got one xs power battery group 3400 and two 3100 . I do have some belt slip ... just when it shift at higher rpm ... I was going to get a slightly smaller belt to see if it fixed that .... nothing's hooked up at the moment ... so  there is no load on it ... I believe this truck does have a PCM controlled altinator ...there is not much I can do about that
it is PCM controlled. GM vehicles 2004 and newer received that "upgrade". You can get around it by having dual alternators. leave your stock alternator for the truck, to be controlled by PCM, and use your Singer alt separately for the aftermarket stuff. The singer alt will need to be self excited. Contact Mike Singer about accomplishing that, and he'll likely only charge you parts plus shipping to get it done for you. it might sound tedious to have two separate electrical systems in one vehicle, but it's rather simple.
edit: I'd like to correct myself. I believe 06/07 is when they started the PCM b/s, I got confused with that stupid current sensor they started in 04.
it would attach next to the current alt with a proper mounting bracket. if youre contacting singer you should receive parts that are essentially "plug and play", no modification, or little to none, it should all bolt on
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
  • Who's Online   0 Members, 0 Anonymous, 375 Guests (See full list)
