Dual Battery System dying over night HELP?
Yep the multimeter is the way to go. I also am not proficient in using one but every time I have to do something I consult with YouTube or Google to make sure I am on the right track. It can seem overwhelming with all the settings and whatnot but just break it down to the task at hand and you will be fine.
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
its definitely not your alt, if it was your truck wouldn't remain running after you jumped it.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
You said the batt u have was only a year old? No warranty? Also if u have a walmart near u they sell a super cheap battery for 50 bucks that comes in a small variety of cranking amps with a 1 year warranty. It may not be the best but will work till u save for somethin better. At least ud be able to start ur truck. Just make sure ur secondary batt is still good. Otherwise you will have the same issue.
Couple questions:
- What's your charging voltage? Check at the alternator and again at each battery
- How quickly does the battery drop to 10v before continuing to fall off?
---What happens if you disconnect your secondary battery? What's the voltage v. time behavior of each?
- How are your batteries wired?
- Do they have removable caps such that you can see each cell?
- Have you performed a parasitic draw test?
