As someone who has ran that much power, I had dual alts (320 and a 270a) and 6 group 31's plus stock group 34 to stay in the low 13's and high 12's. You could probably get away with 5 - 6 batteries on 1 alterator
Ok thanks homies. Yea it’s rms. I got an 8k on subs. Which still ain’t enough and 3.2k on mids n highs. I’m unable to run big alts due to the pulley on them I’ll burn them. I’m in the middle of getting a pro charger installed so largest I can do is 250. I’ve got two d3400 under hood I’m just trying to get my shit together so that my volts don’t fall through the floor lol
Yea, just keep in mind, with a smaller alternator set up and bigger bank, if voltage gets low, it takes a bit longer to charge up than multiple alternators on lesser number of batteries. All in all, it is easily doable to do what you want to do. Buy some batts, aluminum or copper bar stock, drill and tap, and your ready to go.
Edited by ChevyBoy95
  • 1 month later...
  • Who's Online   1 Member, 0 Anonymous, 1137 Guests (See full list)
