akuma4u Posted December 25, 2017 Report Share Posted December 25, 2017 hi can someone please tell me if this design works and is accurate? 2 cubes net @ 38 hz also,.. is it possible to delete threads? i kinda made a couple that are too similar and want to get rid of one.. Link to comment Share on other sites More sharing options...
the_village_idiot Posted December 26, 2017 Report Share Posted December 26, 2017 i tried to use your dimensions and this is what i came up with Link to comment Share on other sites More sharing options...
the_village_idiot Posted December 26, 2017 Report Share Posted December 26, 2017 just my 2cents, it looks way off. Its showing 1.49 cubes net, and a 44.06hz tune and waaaaaay too much port area per foot. Correct me if i entered any information wrong. Link to comment Share on other sites More sharing options...
the_village_idiot Posted December 26, 2017 Report Share Posted December 26, 2017 If you want to get some real help you will need to provide your rms power to the driver and your maximum area measurements for a box aswell as the vehicle its going in. Im pretty new when it comes to this box designing thing, but ive spent TONS of hours reading every bit of good info i can find. So far ive designed and built 12 boxes and they have all turned out awesome. Download the torres box calculator and winisd and just start playing with your measurements and you'll find something that works good. I can help you design something if you'd like. So far ive came up with some decent stuff. Link to comment Share on other sites More sharing options...
akuma4u Posted December 26, 2017 Author Report Share Posted December 26, 2017 The only thing you entered wrong was sub displacement but that doesnt help matters as its .21 not .08. I also was very confused with this design and torres results they r way way way too off but the guy who made me this design told me to screw torres and use his...but i dunno i wanted confirmation first its accurate before i build Link to comment Share on other sites More sharing options...
the_village_idiot Posted December 26, 2017 Report Share Posted December 26, 2017 So far ive been using Torres for my designs and its been very accurate for me. Link to comment Share on other sites More sharing options...
the_village_idiot Posted December 26, 2017 Report Share Posted December 26, 2017 Corrected the disp. That was my fault, i never changed if from my last build lol. But after that correction it made it worse. Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted December 26, 2017 Report Share Posted December 26, 2017 4 hours ago, the_village_idiot said: Corrected the disp. That was my fault, i never changed if from my last build lol. But after that correction it made it worse. That style of port is a 3 common wall slot port. You need to enter in a "3" in the "# of Common Port Walls" field in Torres. It changes the tuning significantly. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted December 26, 2017 Report Share Posted December 26, 2017 7 hours ago, akuma4u said: hi can someone please tell me if this design works and is accurate? 2 cubes net @ 38 hz also,.. is it possible to delete threads? i kinda made a couple that are too similar and want to get rid of one.. I built the box in Sketchup. Here is what I found. The net volume comes out at 1.8525 cu ft (2.0625 - .21 for sub displacement). The port total length is 28.5". Based on my own experience, I bet your tuning comes out at about 39 Hz. Torres came pretty close, but not quite perfect. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
akuma4u Posted December 26, 2017 Author Report Share Posted December 26, 2017 hey triticum thanks for that!... the port area on this design is 42sq in so it just clears the minimum port area amount which i found using your very useful port area calculator.. i do have another design i made using torres .. can u put that into sketchup as well and tell me what you get for net volume.. port length and tuning? based on those results, compare which design you think would yield better results in output and sq and then i will go ahead and build it. BTW,. when you said in sketchup the port total length came out to 28.5 is that the length of the physical port length? here is the other design: (im trying to aim for the lowest tuning possible but due to the fact i want as much port area as possible AND i have limited space.. the tuning is hard to get under 37hz.. unless u have a special trick that can get it lower whilst keeping the port area at the minimum amount as per your calculator.) Link to comment Share on other sites More sharing options...
