Terminal bolt material
I will be using bolts for terminals on my wall. I have always used stainless steel bolts and nuts, but I am wondering if using an aluminum bolt, or even copper would make any difference in conductivity. I’ll be putting about 3k clamped of power through each bolt, so I just wanna make sure That I’m not limiting anything by using stainless, or if it’s worth the extra money to go aluminum.
Anyone have any input? Spend more for aluminum bolts, or just stick with stainless steel?
Fi Team 18's (4)
Crossfire 16k
Crossfire 400.4 & 800.4
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
Stainless steel isn’t a great conductor. I use aluminum bolts just to error on the side of better conductivity. With that being said, I doubt it makes much difference in real world performance. You could probably measure the resistance through your stainless bolts and then we could figure out if you are losing anything.
Builds:
I figured the difference would be negligible. Just wanted to make sure I wasn’t loosing out on some power because of it.
Fi Team 18's (4)
Crossfire 16k
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
I run 3/8" aluminum bolts on my enclosure, but I measured resistance with stainless and it didnt make a difference.  I also add copper washers everywhere I can fit them but that might just be overkill on my part.
IG @walledsonic
Yea, it comes down to running it though a thick bold at a VERY short distance, so loss is probably negligible.
Id use aluminum bolts simply because of the risk of galavanic corrosion occuring between the steel and aluminum.
I was asking our plant electricians awhile back for some copper bolts. After I explained what for they just said grab the stainless ones. They said it wouldn't make a difference. Now whether they were to lazy to get me the copper ones Or not is a different story.....
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
I looked everywhere for 3/8” or 10mm copper threaded rod. No dice. Considered getting round bar and threading it, but aluminum is so cheap and easy to get it just doesnt make sense to bother threading a bunch of round bar
IG @walledsonic
it won't make one bit of difference...
Copper is only 2nd best...so if you are gonna play the copper game, you might as well be a baller and go with silver terminals.  :D
Stainless works fine ESPECIALLY at such a short distance like using a bolt for a terminal.
Follow my Tweet (Twitter)
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
