4 chan amp 2012-14 ford focus se
17 hours ago, 9Nails said:
Are you running wires through the doors or to the back of the head unit?
Its easy, i figured it out People were telling me from back of head unit was improper way to do it. but with these new cars with the molex connectors its impossible to run new speaker wire from the amp to door panels. you have to run from the back of the head unit to the amp. and if youre doing crossovers IE, you splice into factory door panel harness to power them. a shop told me the factory wiring on these new cars will easily power 100rms component set speakers
Or you can remove two bolts to take your door off and drill holes for new wire runs. Its way less complicated and labor intensive than trying to splice into sketchy stock wires.
IG @walledsonic
