best way to run 4 runs of 4/0 in 2007 gmc yukon xl?
looking for the best way to run 4 runs of 4/0 from my alternators in front to the rear of the vehicle, hoping somone has photos or a build log let me know!!
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
Have you thought of running them underneath?
Along the inner frame rail.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • 3 weeks later...
I will run them underneath I'm doin grounds from alt mounting bolts(4runs 2/0) and positive runs off alts (4 runs at 2/0) whats the best way to get from under the truck into the rear cabin area? do I gotta cut the floor for that many? prolly huh
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Apparently my old pics don't work in my build log(s) for 2007 Tahoe, didn't get grandfathered in ?
Anyway, Since I ran two batteries underhood I ran power wires from battery that was on drivers side up to the firewall, where the brake fluid reservoir sits, then down, underneath, along the frame best I could (this vehicles gets tight underneath, too much factory crap packed between frame rails)  then I made a hole behind drivers side rear wheel well (inside factory interior panel where cubby is) and that is where they came up.  Same as the grounds, I grounded straight to frame back there, but I also used two separate alternators, thus 2 separate charging systems to avoid the B.S. factory ground loop sensor, otherwise you can only ground to front battery ONLY.  I had ALL interior out at one point and STILL on a vehicle like this choose to run wires underneath.  Don't need to jack it up or anything.  ?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
yea to many runs to go thru the vehicle, I was thinking of doing the 370s on the battery bank and amps separate from the stock alternator to run the rest of truck and 4 channel not sure what this ground loop sensor is?
can you elaborate on the area you ran your wires through? to bad your pics are gone that sucks.
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Do this:
and then check out Karkov’s build log. Also check out my buddy’s Jeep, we had to run them under the vehicle and into the cabin thru a pvc connetor. Then bsckfilled with silicone like karkov had done. Here’s the post:
IG @walledsonic
Thanks WalledSonic, but my pictures no longer work in all my build logs (pisses me off).  I have been PM'ing OP
We'll get him there
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
@rocking.that.eclipse @KarkovDid the photobucket link solution I posted not work for yall?
IG @walledsonic
  • Who's Online   0 Members, 0 Anonymous, 200 Guests (See full list)
