Mini Bass Meter - Sound pressure meter with voltmeter function
Mini Bass Meter
    • Completely autonomous
    • Bright display
    • Frequency range from 20 to 120 Hz
    • Amplitude range from 120 to 160 dB
    • Measuring voltage from 1 to 20 volt*
    • Calibrated according to TERM-LAB Classic and Magnum
    • Updatable software
Mini Bass Meter – Sound pressure meter with voltmeter function
Download Spl-Lab
Video
Description
Spl-Lab Mini Bass Meter is a new device for measuring sound pressure and voltage. This device is, probably, the most compact SPL meter of those available on the market today. The uniqueness of this device is in its capability of simultaneously measuring sound pressure and voltage. At the same time, it is possible to capture sound pressure at the moment of reaching the highest SPL value. The measured signal can be provided by both industrial equipment and acoustic systems. The device is simple in use and does not require additional settings and calibration. It is enough to simply connect the device to a car cigarette lighter for measuring sound pressure and voltage. The device can be attached to the windshield of a car and the measurements taken while driving. The Mini Bass Meter is completely autonomous, which eliminates inaccurate readings.
Ergonomics
Spl-Lab Mini Bass Meter has a compact case, including a four segment display, 3 control buttons, Mini-USB slot for power supply and updating the firmware and an input for connecting to a cigarette lighter socket. The design of the device allows it to practically fit into any car interior.
Functions
  • Measuring sound pressure level (SPL)
  • Measurement of current, maximum and minimum voltage
  • Measuring the frequency of the peak spectrum composes
  • Measuring voltage at the moment of reaching the highest SPL value
  • Measuring the performance of home, car or concert speakers
  • Speaker tune, such as subwoofers
  • Noise measurement
  • Preparation for caraudio competition for unlimited sound pressure (AMT, EMMA, dB Drag, IASCA, and others.)
Mini Bass Meter
Edited by dr.Gonzo
  • Thanks (+1 Rep) 1
  • Who's Online   1 Member, 0 Anonymous, 1858 Guests (See full list)
