Port noise
Ernest
That should be enough port area.  What's your intended tuning frequency?
Builds:
Even tho its enough port area, does the increased surface area in the port due to the 10:1 aspect ratio cause more friction? Is there an aspect ratio you recommend in general for slot ports?
IG @walledsonic
The high aspect ration certainly isn't ideal.  I like to keep aspect ratios under 5:1 if possible and 8:1 is my absolute upper limit.  Increasing port area can compensate for an undesirable aspect ratio.  In the OPs case, he has enough port area it shouldn't be a problem.
Builds:
Yes the high aspect ratio is a problem that I am concerned about. What are the negatives that I should expect from it being that high? Will it cause port noise, or just loose a bit of output due to the higher surface area...”are the sparks going to ignite the fumes or my dust cap going to twist”?
  • Who's Online   1 Member, 0 Anonymous, 1477 Guests (See full list)
