Dragonware Posted June 20, 2018 Report Share Posted June 20, 2018 Id like a down firing ported enclosure if anyone can help me id appreciate it, Possibly having the port external some how to save on internal displacement if possible . Im lifting the seat so dimensions are Depth 13 Front height 11.5 Rear height 8.5 Width - 54 since down firing please counter sink as well and if at all possible 2 plexiglass windows ? optional im pushing it lol 2 x 12 in RE audio SEX first gen. Reconed with PSI parts dual 1ohm Powered by a hifonics BRZ2000.1D I need a simple sketchup diagram with dimensions I should be able to figure out all the cuts and parts just let me know the angles used. Recommended Enclosure Type Ported / Vented Sealed Minimum Sealed Box Volume 0.75 cubic feet Optimum Sealed Box Volume Maximum Sealed Box Volume 1.0 cubic feet Minimum Ported Box Volume 1.5 cubic feet Optimum Ported Box Volume Maximum Ported Box Volume 2.0 cubic feet Top-Mount Depth 7" Cutout Diameter 11-1/4" Shallow Mount Installation No My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
ckeeler11 Posted June 20, 2018 Report Share Posted June 20, 2018 You are going to be a little on the small side to run ported. You have 3.5 cu ft. to work with and that does not account for the space you need for the subs excursion on the bottom., so probably closer to 3.0 cu ft. You want to be around 4-4.25 most likely. Link to comment Share on other sites More sharing options...
shredder2 Posted June 20, 2018 Report Share Posted June 20, 2018 Pair of 10's is pushing it in that space ported imo... here is one for 2-Sa 10's in that approximate space you've got... 2 12's ported looks like a bit of a stretch. Link to comment Share on other sites More sharing options...
bmwking Posted June 20, 2018 Report Share Posted June 20, 2018 54 minutes ago, shredder2 said: Pair of 10's is pushing it in that space ported imo... here is one for 2-Sa 10's in that approximate space you've got... 2 12's ported looks like a bit of a stretch. did you design that bad boy? Link to comment Share on other sites More sharing options...
shredder2 Posted June 20, 2018 Report Share Posted June 20, 2018 Yes... I'm a lurker on this forum mostly... but HAD to add my .02 regarding 2-12's underseat ported in this instance. I felt an illustration would be best to make my point. Sealed maybe... ported in space listed... imo, no. Winisd/ Torres/ Sketchup... yes, it's my design. Link to comment Share on other sites More sharing options...
bmwking Posted June 21, 2018 Report Share Posted June 21, 2018 2 hours ago, shredder2 said: Yes... I'm a lurker on this forum mostly... but HAD to add my .02 regarding 2-12's underseat ported in this instance. I felt an illustration would be best to make my point. Sealed maybe... ported in space listed... imo, no. Winisd/ Torres/ Sketchup... yes, it's my design. its very nice! Link to comment Share on other sites More sharing options...
Dragonware Posted June 21, 2018 Author Report Share Posted June 21, 2018 3 hours ago, shredder2 said: Pair of 10's is pushing it in that space ported imo... here is one for 2-Sa 10's in that approximate space you've got... 2 12's ported looks like a bit of a stretch. I had a design done for me for 3 x SD3 -10s sealed but the subs are costing me 1000 dollars when I already own these two 12s, and the lift kit was $163. I would like ported but sealed is not a deal breaker if I can use my existing 12s. or perhaps 1 x 12 ported. My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top Link to comment Share on other sites More sharing options...
Ron36 Posted June 21, 2018 Report Share Posted June 21, 2018 Hey Shredder 2 what size and length port in that box u designed 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery Link to comment Share on other sites More sharing options...
shredder2 Posted June 21, 2018 Report Share Posted June 21, 2018 IIRC its 5.9" ID 24" long or so... don't quote me as the drawings are on my computer, not Chromebook... it's been several months since I did the design so it's just a WAG atm... sorry It's around 11in2^ft3 I think Link to comment Share on other sites More sharing options...
