bmwking Posted July 14, 2018 Report Share Posted July 14, 2018 hey all, time for me to get around to making something for that custom sub i built a few months back. i couldnt get any reliable DATS readings off it so i'm just gonna wing it and make a box between the needs for a meso 10 and a 12. which puts it at 1.375 cu ft i cant get optimal port area in torres at tuning for some reason. If anyone could come up with a quick dimensions list for a 1.375 cu ft ported box (mid/low 30s tuning is fine, whatever is easiest), that'd be super helpful! oh and the sub displaces about 0.15 cu ft by my estimate. will be putting it on 1800w rms thanks guys! Link to comment Share on other sites More sharing options...
Hellbilly429 Posted July 17, 2018 Report Share Posted July 17, 2018 What are your max dimensions? Tuning low with that small of a box and the port area you require is going to be extremely difficult. From what I can guestimate (CT doesn't list all T/S specs for the Meso 12) it looks like this sub will do well around 32hz to keep it from being too peaky. 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log Link to comment Share on other sites More sharing options...
bmwking Posted July 17, 2018 Author Report Share Posted July 17, 2018 5 hours ago, Hellbilly429 said: What are your max dimensions? Tuning low with that small of a box and the port area you require is going to be extremely difficult. From what I can guestimate (CT doesn't list all T/S specs for the Meso 12) it looks like this sub will do well around 32hz to keep it from being too peaky. max dimensions would be 43" wide (if that width no side port), 16" height, and 25" depth. should be more than enough room i hope! appreciate any help you can give man Link to comment Share on other sites More sharing options...
Hellbilly429 Posted July 18, 2018 Report Share Posted July 18, 2018 Really hard to get an accurate reading from WINISD since I'm missing parameters for the sub, but it looks like it should be fine with a 35hz tuning at 1.33 net, getting you port area of 33 (min. is 26 according to Triticum's calculator, and optimal is 35.) WINISD is graphing that with 1800 watts applied, your port velocity should be below 24 m/s. Definitely use subsonic filter at 25-28hz to not exceed excursion limits at lower frequencies. 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log Link to comment Share on other sites More sharing options...
bmwking Posted July 18, 2018 Author Report Share Posted July 18, 2018 Awesome man, thanks for your help! I thought such a narrow port would raise the velocity. This is when I like being wrong haha Link to comment Share on other sites More sharing options...
Hellbilly429 Posted July 18, 2018 Report Share Posted July 18, 2018 It's the port area that matters, not the dimensions of the port. You are welcome! 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log Link to comment Share on other sites More sharing options...
ckeeler11 Posted July 18, 2018 Report Share Posted July 18, 2018 31 minutes ago, bmwking said: Awesome man, thanks for your help! I thought such a narrow port would raise the velocity. This is when I like being wrong haha 29 minutes ago, Hellbilly429 said: It's the port area that matters, not the dimensions of the port. You are welcome! I would not go over a port ratio of 10:1 as efficiency starts to go down. Link to comment Share on other sites More sharing options...
Hellbilly429 Posted July 18, 2018 Report Share Posted July 18, 2018 Following Triticum's port calculator, and it lists optimum port area to be 35 inches squared for a 1.3 ft^3 box with 1800 watts applied to it. Edit: misunderstood both of your comments, sorry guys! Port ratio of 1:1 is ideal, but I do not think the port ratio of 1:8 will hurt him. Do you want me to re-calculate with a square port instead of a slot to be safe? 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log Link to comment Share on other sites More sharing options...
bmwking Posted July 18, 2018 Author Report Share Posted July 18, 2018 56 minutes ago, Hellbilly429 said: Following Triticum's port calculator, and it lists optimum port area to be 35 inches squared for a 1.3 ft^3 box with 1800 watts applied to it. Edit: misunderstood both of your comments, sorry guys! Port ratio of 1:1 is ideal, but I do not think the port ratio of 1:8 will hurt him. Do you want me to re-calculate with a square port instead of a slot to be safe? nah, im alright with a good tight slot Link to comment Share on other sites More sharing options...
Hellbilly429 Posted July 18, 2018 Report Share Posted July 18, 2018 Agreed. Little easier to make and what not. 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log Link to comment Share on other sites More sharing options...
