sundown audio x6.5 box help
Noah Lee
wanting to build a box for 2 sundown x6.5 subs says they require 0.3ft each.  my measurements are 20" W 10"H 10"D with a 2" round port 10.8 long tuned to 32hz this should leave me with an overall internal cubic feet  of 0.66 after dismantlement would this work ?
Any help much appreciated.
My math shows a gross int volume of .77 ft3, and a port volume of .019 for a net of .75 before sub displacement, .05 x 2 for sub displacement and you have an end net vol of .65.  Looks good to me.  I didn't do any calc's to see if your port tuning is correct.
Cheers bud hopefully I’ve got the tuning right for the port. That’s what it told me on 12volt box calculator for 32hz
Your probably going to have to bump up to a 3" round port. A 2" is too small. Only 3.15 area of port with a 2"
05 TL build log SOLD
But wouldn’t a 3 inch round port need to be around 25.5 inches long so there for wouldnt take away to much of the internal volume ?
yes it would need to be longer but you need to have the proper port area for the enclosure to function properly.
And welcome to the world of compromise... lol it sucks...
I havent run the numbers, but a 2" is bound to be too small. Anytime your port length is only 10" for a mid 30s tune, it's too low on port area.
Now you get to figure out how to fit a 25" long port in a 20" wide box. That's usually how box making goes unfortunately.
So here is a suggestion with proper port area, dims close to your own (and can be customized), power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 1 1/4", figure is just an assembly guide:
  • Who's Online   0 Members, 0 Anonymous, 212 Guests (See full list)
