Mutli mono amps problem
Neo2020
Running two mono amps, one per sub. Signal out for HU is 5v. Running preouts to first (main) amp and second amp is connected to output of first amp. Problem is second amp sub is lower than the main amp sub. Can clearly see the difference in flex. Both amps are the exact same model and same settings. (Gains,boost,etc). Each amp has separate power wires. Running two 4 gauge OFC power cables (same length). Only thing I can think of is the second amp rca is about 15ft long connected to the first amp.
Need any input of what could be wrong.
Can u strap the amps together, they would work with each other then.
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
Certain amps may filter out either high or low pass signals wich could be causing the issue. Its good to have your rcas as short as possible because the long length can cause drops in voltage wich could very well cause your issue. Your best bet is to order a few female to male rca splitters and a couple 1 ft rca cables. Just split the left and right channels and run one left and one right to each amp. Ditch the bass knob. All they do is cause distortion. If you want 1 knob to control gains on both amps buy a pac lc1. It goes inline with your rcas so you can instal it in the front to control both amps.
the position of the gain knobs means very little. you have to use the proper tools to measure the amps output to ensure each amp has the same output.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 1159 Guests (See full list)
