Jdavis51 Posted September 12, 2018 Report Share Posted September 12, 2018 On 9/10/2018 at 12:54 PM, kalilac619 said: What walled sonic said...I run caps and lithium and I've tested pretty much every scenario and while caps do work excellent for burps not so much for demos/sustained draw without enough alt power.... 45ah should be good...I run a 40ah juicebox lithium and it held about better voltage then my 3 NorthStar agms direct swap What would you consider enough alt power in this situation Link to comment Share on other sites More sharing options...
kalilac619 Posted September 12, 2018 Report Share Posted September 12, 2018 32 minutes ago, Jdavis51 said: What would you consider enough alt power in this situation Depends on the power being ran and how many caps you're running...I run close to 700 amps of alt power and 6 banks of maxwell blue caps on 2 sundown scv6000ds wired .5 each and drop from 14.5 to about 13.3 (lithium resting voltage)a minute to a minute and half into a demo full tilt....I'm adding 8 more banks next month 2000 Suburban 6 runs of 2/0 12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door 8 banks of blue Maxwells + 260ah of Yin Long LTOs 2 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 161.6@38hz DBdrag sealed on the dash… 162.54 outlaw…161.14 Meca headrest Link to comment Share on other sites More sharing options...
