Matthew Williams Posted September 13, 2018 Report Share Posted September 13, 2018 I currently have an FI Q 15 Neo. Looking to find something that can slam the lows pretty well. I am using a SKAR audio 2000.1D. Looking to hit 26 - 29hz. Any ideas? Link to comment Share on other sites More sharing options...
Joshdashef Posted September 13, 2018 Report Share Posted September 13, 2018 The fi sp4 v2 is great on the lows but really needs 3k+. Might be able to use the 2k with a bigger box SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
Matthew Williams Posted September 14, 2018 Author Report Share Posted September 14, 2018 6 hours ago, Joshdashef said: The fi sp4 v2 is great on the lows but really needs 3k+. Might be able to use the 2k with a bigger box Are there any other options? Ive been trying to move away from FI and I cant fit an 18 in my focus Link to comment Share on other sites More sharing options...
audiofanaticz Posted September 14, 2018 Report Share Posted September 14, 2018 Sundown X-15 (version 2) should be great on your current power, though the Fi Q neo 15 shouldnt have any issues playing low either. Sounds to me like a better suited box for your wants and needs is a better option. Link to comment Share on other sites More sharing options...
Joe X Posted September 14, 2018 Report Share Posted September 14, 2018 22 hours ago, Matthew Williams said: I currently have an FI Q 15 Neo. Looking to find something that can slam the lows pretty well. I am using a SKAR audio 2000.1D. Looking to hit 26 - 29hz. Any ideas? I would suggest to fully describe and picture your setup, including a sketch of your box with dimensions, could be as simple as disabling or lowering your subsonic filter or other settings in your system. Link to comment Share on other sites More sharing options...
Matthew Williams Posted September 14, 2018 Author Report Share Posted September 14, 2018 What I will do is post pictures of the box with measurements. The guy that built the box told me it would be tuned to 33hz but whenever I try to hit anywhere near 27hz, its trash. So I will get you guys the stuff now. Stand by. Link to comment Share on other sites More sharing options...
Matthew Williams Posted September 14, 2018 Author Report Share Posted September 14, 2018 The area the box can fit in back here is 35L x 24W x 19H Link to comment Share on other sites More sharing options...
audiofanaticz Posted September 15, 2018 Report Share Posted September 15, 2018 Whats the port width? It looks like its about 4 inches. Also how long is it? Looks like a double baffle as well, correct? Any internal bracing? From what I am seeing doing rough math some unknown variables but taking an educated guess is: Box volume is 6.31 cubic feet after sub and a rough port displacement. Fi recommends 3-5 cubic feet after all displacement. Port area is about 70 square inches or 11.09 square inches per cube of box volume. So its on the lower side of things, but considering the box is larger than spec and your using more power than rated so it maybe better off. However I took an educated guess on the port width of 4 inches which it maybe a little wider or narrower and that would through off these numbers a bit. I also took a guess on port length and made it the length needed to get 33hz, but again however if the builder used a wack program that is not accurate or didnt build it right or any other possibility it may not even be 33hz so it would be best to know both the width of the port and the length. As @Joe X also stated what are your settings on the amp set too as well? If your subsonic filter is set too high your going to be not playing those lower frequencies to loudly. Link to comment Share on other sites More sharing options...
Matthew Williams Posted September 15, 2018 Author Report Share Posted September 15, 2018 Port is 4in W 18in long Box is double baffled Link to comment Share on other sites More sharing options...
Matthew Williams Posted September 15, 2018 Author Report Share Posted September 15, 2018 44 minutes ago, audiofanaticz said: Whats the port width? It looks like its about 4 inches. Also how long is it? Looks like a double baffle as well, correct? Any internal bracing? From what I am seeing doing rough math some unknown variables but taking an educated guess is: Box volume is 6.31 cubic feet after sub and a rough port displacement. Fi recommends 3-5 cubic feet after all displacement. Port area is about 70 square inches or 11.09 square inches per cube of box volume. So its on the lower side of things, but considering the box is larger than spec and your using more power than rated so it maybe better off. However I took an educated guess on the port width of 4 inches which it maybe a little wider or narrower and that would through off these numbers a bit. I also took a guess on port length and made it the length needed to get 33hz, but again however if the builder used a wack program that is not accurate or didnt build it right or any other possibility it may not even be 33hz so it would be best to know both the width of the port and the length. As @Joe X also stated what are your settings on the amp set too as well? If your subsonic filter is set too high your going to be not playing those lower frequencies to loudly. @Joe X @audiofanaticz - Amp settings: subsonic is set to all the way off. Crossover is set to 40 or lowest possible setting based on the amp. Link to comment Share on other sites More sharing options...
