hifonix Posted September 24, 2018 Report Share Posted September 24, 2018 I purchased a used US Acoustics USX-800f zed made amp. It came with a mix match set of fuses in the amp (automotive style.) I found the owners manual and fuse rating is 40a, would I be correct in assuming that it means 4x10a fuses? Power Ratings for amp 300 x 2 @ 4 ohms 400 x 2 @ 2 ohms 800 x 1 @ 4 ohms Under Construction Link to comment Share on other sites More sharing options...
CleanSierra Posted September 24, 2018 Report Share Posted September 24, 2018 And you can probably run at .25 ohms if you can feed it all the voltage it needs. Those old amps can be wired in the dirt with no problem if you can supply their demands. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
