Tintn Posted November 17, 2018 Report Share Posted November 17, 2018 I have a 2007 chevy avalanche. I did my big 3 upgrade today unhooked the battery first then made all my connections. 1+battery to alternator +. 2 ground to frame (cleaned frame first) 3 ground to motor. 4 body ground to motor ground. Hooked battery back up went to start truck nothing happened. Checked all connections tried again nothing. My front windows work,horn works dash lights work (tpms,check engine,etc.) Door locks, radio,key fob,interior lights don't work now? I also checked all the fuses all are good...please help Link to comment Share on other sites More sharing options...
8v fury Posted November 17, 2018 Report Share Posted November 17, 2018 Does you vehicle have a alarm or immoblizer? Pushing it to the limits. Want more power. Link to comment Share on other sites More sharing options...
AlpineNut Posted November 17, 2018 Report Share Posted November 17, 2018 1st I would check with a voltmeter to make sure everything is getting 12v signal, one thing is the remote wire hooked up? 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n Link to comment Share on other sites More sharing options...
Jessica Posted November 17, 2018 Report Share Posted November 17, 2018 12 hours ago, 8v fury said: Does you vehicle have a alarm or immoblizer? Bet this is it. And now to sit with the key in the on position for 20 minutes Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Tintn Posted November 17, 2018 Author Report Share Posted November 17, 2018 13 hours ago, 8v fury said: Does you vehicle have a alarm or immoblizer? It has factory alarm Link to comment Share on other sites More sharing options...
AlpineNut Posted November 17, 2018 Report Share Posted November 17, 2018 1 hour ago, Tintn said: It has factory alarm I have a 2005 Silverado and have never had a issue an it also has a factory alarm + remote start alarm and I redid my entire system a few months ago and not a single issue. It has to be in the wiring, check the + & - leads at the amps an also the remote wire, one of them is causing the issue 73456w9vbwevsdb sodtbsorutnvsd sdtuspdun sd d f gsdfiusd gdf n Link to comment Share on other sites More sharing options...
Tintn Posted November 17, 2018 Author Report Share Posted November 17, 2018 17 minutes ago, AlpineNut said: I have a 2005 Silverado and have never had a issue an it also has a factory alarm + remote start alarm and I redid my entire system a few months ago and not a single issue. It has to be in the wiring, check the + & - leads at the amps an also the remote wire, one of them is causing the issue It's not my amp I'm worried about my truck will not start not even turn over checked everything 10x Link to comment Share on other sites More sharing options...
Jessica Posted November 17, 2018 Report Share Posted November 17, 2018 Did you replace any wires or only add wires? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Tintn Posted November 18, 2018 Author Report Share Posted November 18, 2018 7 hours ago, strangeduck said: Did you replace any wires or only add wires? Link to comment Share on other sites More sharing options...
Tintn Posted November 18, 2018 Author Report Share Posted November 18, 2018 Just now, Tintn said: I just added wires Link to comment Share on other sites More sharing options...
