ehall8702 Posted January 19, 2019 Report Share Posted January 19, 2019 I have solid plans for a new slot port box for my xfl, just been wondering how much more output i would get from a bandpass, 4th order 6th order? I have absolutely no clue which is better, why, or if its worth building a bandpass when i listen to mostly music. Im pushing 2k to my sub and have no idea how power ratings and bandpass even works. Any input would be great. Not sure if i wanna attempt it or not but my current slot port moves ALOT of air, just wondering how much more a single 12 can move. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
ehall8702 Posted January 19, 2019 Author Report Share Posted January 19, 2019 Even a t-line isnt out of the question, i have 4.5 cubes to play with. Any one do any modeling i can put up some measurements if ya want. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
Joe X Posted January 19, 2019 Report Share Posted January 19, 2019 This sub can work both in 4th and six bandpass boxes, the main advantage with bandpass boxes is more control over bandwidth , with ported high efficiency is mostly around tuning. Link to comment Share on other sites More sharing options...
ehall8702 Posted January 19, 2019 Author Report Share Posted January 19, 2019 So what would be the most efficient from 80-90ish down to whatever is as low i can get with the 4.5 cubes? I have built ONE bandpass box in my life. Was a blow through for 4 10's in a standard cab ranger. Had 4 4" ports from box in bed to inside of cab. Straight dumb luck it sounded pretty good, cant even remember how i came up with measurements back then. I got 37" wide and i think 15" high, deep is like 30 something ( its -2* out so no real measurement and i havent had to measure max for any other box before) any help in a usefull design for a bandpass would be awesome, hell or even a program i can play arpund with on my computer to design one would be great too. Im not great with those programs but willing to give it a shot. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
