Dragonsyph
Fuse holders that won’t break the bank.
Cheapest I’ve found are single holders from sky high for 8 each, mechman has some for 6 but there not ring terminals.
I heard you want rings and not set screws is there a reason? Guessing set screws went very secure.
SMD 4 fuse holders are real nice with a buss bar on one side but are 55 each, would live some of them but that’s like 180 just in holders.
Iv seen some make there own with wood and steel bolts but that shits hella ugly.  If I went that route I’d have to do research on best materials.
Can I run 2 runs from alt and 2 from front battery to a buss bar, then two fuses from bussbar to 2 runs to the back? Then reverse that with two to the back bat and two to the amp all fused again?
So two at front two at back them two before amp?  About 6 fuses min.
Just trying to save money anywhere I can but at the same time want quality and didn’t hurt to look good too?
Edited by Dragonsyph
Sundown NSV4 18"  +  Orion 5000.1dV2
MechMan Elite 370a  +  XS3100 - XP3000
SHCA 1/0 OFC(blue+  SMD Fuse Holders(blue)
Pioneer AVH-2440NEX  SHCA Pro RCA
Share this post
Link to post
The cheaper SHCA ones, ... are just that ., cheap. Can they work,... kinda.
I hated the 12 SHCA cheap ones i ran in my blazer build.  They broke, all the time. I dont know what to recommend you, ... as, i do like the SMD ones we have in the burban build,  but, i can say, get something, a bit better than the lower end SHCA ones. Just my .02
Share this post
Link to post
Making distribution blocks inspired by the pic here is on my to do list. I just scored a bunch of free copper plate, which is a good conductor. I'm going to use wood, copper, aluminum and stainless. I have gathered an abundance of these materials off the free section of craigslist.
Share this post
Link to post
I’ve used these for years never had an issue got about 15 of them , they do the job.
Edited by Ron36
  • Thanks (+1 Rep) 1
3 Sundown SA-10's D4 ohm
American Bass VFL 120.1 Running at .6 ohms
250amp alternator
Mids all Alpine type R 's 2 set's of 6.5 components and 1 set of 6x8's
3 Rockford PBR's 300x2
6 Kinetic batteries
F150 Supercrew 2010
Share this post
Link to post
I like the Rockford Fosgate joints for single fuse ( or multiples) but their expensive so this comment is useless. Lol. They do make the nicest ones tho imo
Share this post
Link to post
Used those in my acura build years ago. They are nice. But, ya,.. a bit costly. I got mine, at a decent deal, from Tony Candela (CE auto supply dude), with some rad RF cable (power/ground runs, rca's and shit).
Edited by Kyblack76
Share this post
Link to post
I have like 8 RF analog fuse holders in a box sitting around. Switched to SDM style. They are nice but bulky and take up room when you need a few of them.
SINGER 200 amp HO ALT
Big 5 0 AWG-RF Wiring
Optima Blue top-under hood
Kenetic HC 600 under hood
2 Kenetic HC1800 in trunk
Stinger VM
DEH-80PRS HU
RF P3 8" mid-bass in custom kick Panels
RF T265 comps x2 in custom door panels
RF T165 comps in Rear Doors
2 SQ HDS310snin a JOE X designed box
RF T400-4 ( x 2 )
RF T400-2
RF Power T1500bdcp.
All RF & SHCA OFC  0,4,8,12 wiring.
Fuse's from SMD & RF.
Share this post
Link to post
Budget wise skip the sky high ones. I used them with their own wire and lugs and the tops wouldn't fit on at all. I went with SMD and I won't go back, but since you want to get the best bang for your buck I think making your own might be the cheapest way to get something that won't break on you. You could always make a fuse holder a part of your build - i.e. the wood you use to hold your battery/amp rack/etc. like this guy did. 87c5eb3f.jpg
Not saying its pretty by any means but it seems about the cheapest way to do it. You could see if anyone sells acrylic covers to put over the bolts or make your own.
  • Thanks (+1 Rep) 1
My Daily 8th gen Civic Coupe
https://www.stevemeadedesigns.com/board/topic/211131-honda-civic-coupe-08-2k-daily-headaches/ (Build Log)
Gear (specifics on build log)
Pioneer 80 PRS / RF P600x4 / DC 2k / Mechman 240 A / XS D3400 + D5100R / Two SA-12(D4) / RF T2 Components / Sky High Wiring (OFC)
~3.6 Cubed Net / 34 Hz Tuned / Center Port
Share this post
Link to post
Thanks everyone for all the advice,  def won’t buy the sky high ones.
That looks pretty cool, I might try that out, what kind of hardware should I use? Iv read steel is not very good, maybe zinc or nickel coated or something ?
Nice those look decent and a good price too.  Good option thanks.
Share this post
Link to post
