DiBo Posted February 11, 2019 Report Share Posted February 11, 2019 I got another Apocalypse AAK40001D and was thinking of ditching dual inputs for 2 2/0ga wires per amp. Total of 4 positives and 4 negatives between the 2 amps. 2/0ga is rated for 400+ amps per run and more per short run. Anybody see a problem with this? I don't really see a reason to have the dual inputs. Going with sky high 2/ 0 gauge. Link to comment Share on other sites More sharing options...
Joshdashef Posted February 11, 2019 Report Share Posted February 11, 2019 You can do whatever you want is the beauty of this hobby. Do you already have 3 runs of 0 gauge ? If so do they go into a rear batt bank? Then you could probably just do two 0 gauge runs into each amp and it’d be fine. If you wanted to be ready for future upgrades use four runs of 2/0 like you said if you want but a single 2/0 run would be enough for each amp. The fuse rating is 350 A —————————— They make reducers to fit the 0 gauge inputs on amps with 2/0 or bigger. If you go the 2/0 route get some, I bet it’ll make your life a hell of a lot easier down the road. Since your a fan of sky high wire, same here, here’s a link to their reducers, quite pricey though. http://skyhighcaraudio.com/search.php?search_query_adv=Reducer SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
DiBo Posted February 11, 2019 Author Report Share Posted February 11, 2019 53 minutes ago, Joshdashef said: You can do whatever you want is the beauty of this hobby. Do you already have 3 runs of 0 gauge ? If so do they go into a rear batt bank? Then you could probably just do two 0 gauge runs into each amp and it’d be fine. If you wanted to be ready for future upgrades use four runs of 2/0 like you said if you want but a single 2/0 run would be enough for each amp. The fuse rating is 350 A —————————— They make reducers to fit the 0 gauge inputs on amps with 2/0 or bigger. If you go the 2/0 route get some, I bet it’ll make your life a hell of a lot easier down the road. Since your a fan of sky high wire, same here, here’s a link to their reducers, quite pricey though. http://skyhighcaraudio.com/search.php?search_query_adv=Reducer 3 runs from front battery to rear bank? I also meant single runs of 2/0 to each input. Amp has two positive and two grounds. I ordered a Mechman 370 amp alternator to be my secondary alt but the bracket is $649 and I won't get that till taxes land. When that happens I'll have 3 1/0 gauge runs front to back straight from my alternator or front battery delete distribution. Navi getting 4 Apocalypse 4ks on 4-15's most likely. 6-15's if I go B-pillar. Truck will be SPL full blown by the end of this year. Rt now money is tight as some skinny jeans on my uncle Eddy lol. Trying to save anywhere I can without sacrificing performance. Link to comment Share on other sites More sharing options...
