That would be around 6 cubes net volume. 5.4 ft^3 net for the least if you are going separate chambers. With subwoofer displacement, port & bracing if any, it will be significantly larger. Especially if you use the optimal port area required.
DB Drive WDX2K-12?... in my experience often the manufacturer recommendations leave a lot to be desired so modeling the things on your planned power and in the space you've got available might be something you'd want to do.
I just don't see those things handling 2K rms each, possibly 1K each at best.
If you got any real power... past 2K I'd be careful with tuning and airspace if it was me... of course I'm just a noob
IDK if them coils will hang but for a true 2K amp at 1 ohm I'd do something like this... or close. If you wanted max output I'd try to use an Aero as well.
Idk if building something close to that ^^^ is gonna meet your goals but it ought to not limit output and would give those subs a fighting chance at handling a decent 2K amp at 1 ohm IMO
  • Who's Online   0 Members, 0 Anonymous, 290 Guests (See full list)
