Slot port flares and bracing.
mfdoom7
what if i make slot port with rounded edges inside and outside ? will i loose or gain output ? Also do i need to brace subwoofer blox if its built with 22mm or 0.86inch OSB. we are talking about 1 15" on 1.2k rms right now box is tuned low 30hz. also what effect is on adding 45 to 90 corners. like this one
Having the corners rounded will help with air flow. Doubtful you will hear any difference. The more bracing the better.I would brace any panel over 12" just because the more rigid the enclosure the better.
Why are you using OSB instead of MDF or Birch?
You want air to be able to flow through the port as smoothly as possible.  As such, rounding the inside and outside mouths of the port is a good idea.  This is also why adding the 45 pieces to the inside of the port like what shown in the picture you posted is also a good idea.  It helps the air make the 90 degree corner better.
As far as bracing goes, I completely agree with ckeeler11, I brace any panel with more than a 10-12" unbraced span.  I almost always brace the baffle regardless of how large of panel it is.
Builds:
this is my current box. built with 22mm OSB and 45 on 90degree port and sanded off oposite side of 90. does brace give more output im my case ? or not worth it ?
With that design I would put a shelf brace linking your top, bottom, and port panels together.  You can cut holes in the brace so it takes up less internal volume.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1224 Guests (See full list)
