Brandon evl-18d2 Posted February 27, 2019 Report Share Posted February 27, 2019 Information given by skar audio Sealed Volume: 3.00 ~ 3.50 ft^3 Ported Volume: 3.75 ~ 4.50 ft^3 Port Area: 55.5 sq. in. Port Length: 29.5" Tuning Frequency: 31 Hz Displacement: 0.17 cu ft Mounting Depth: 10.10" Cut-Out Diameter: 16.75" Magnet Diameter: 7.35" Dual 2 Ohm Coil Configuration RMS Power: 1,250 Watts Peak Power: 2,500 Watts Voice Coil Size: 3" 4 Layer Black Aluminum CCAW Voice Coil Motor Weight: 166 oz Frequency Response: 20-300 Hz High Roll Foam Surround Sensitivity: 88 dB Fs: 37 Hz Re: 1.8 Ohms Qms: 5.65 Qes: 1 Qts: 0.85 Mms: 424g Cms: 0.042mm/N Bl: 20 n/a Vas: 81 L Sd: 1164.1cm^2 Xmax: 23.5mm (one way) I seen on another post where people were stating having a port area of 100 sq in + I just need guidance from someone before I build the box. I'm open to suggestions. I have built alot of boxes before but they were for fi btl n2 15s and 18s and I never used a parameter sheet. We measured the area and made the boxes huge, port huge and tuned low (28-30hz) I will be putting a single skar evl 18 in a hummer h3 so space is pretty open and I will be powering the sub with a audiopipe 1500.1 at 1ohm. Please give the total cubes you would run and the port area you would build please. (Plan to tune to 30hz) P.s. I will not lie, I don't understand 90% of the parameter sheet. My box building experience amounts to using a app to measure the box and to tune it and anything past that, imma dumbass Link to comment Share on other sites More sharing options...
shredder2 Posted March 1, 2019 Report Share Posted March 1, 2019 3.75ft3- 4.5ft3... who is in charge of recommenations over there... marketing? Link to comment Share on other sites More sharing options...
