Check out the SMD Store @ WcCarAudio.com!
i am building pods for my doors, the panels are rough and worn out. im thinking of covering the panels with something soft, maybe 1/4 or 1/8" foam to provide some coushin and cover imperfections. then id like to vynal wrap the entire panel. what glues woudl you recomend and what materials for the foam?  there are some tight concave parts to the panels.
99 dodge ram
Share this post
Link to post
1/8 inch closed foam.  Make sure you lightly take a da sander with 220 grit and knock the shiney top layer off the foam on both sides for good adhesion.   As for glue, I use weldwood spray grade contact adhesive and spray it through a hvlp gun with a 1.8 tip
Share this post
Link to post
k, sounds good. something like this? https://www.midwestfabrics.com/1-8-closed-cell-foam.html
i was originally planning to build an enclosure inside the door for the midrange (its deep and the door needs to be cut). however maybe free air would be easier? im worried about back wave radiating into the cab. also worried about the midbass pressure against the midrange if they share air space in the door.
Share this post
Link to post
99 dodge ram
https://store.secondskinaudio.com/closed-cell-foam-ccf-made-in-the-usa/ Check out our selection of high-quality American made Closed Cell Foams for your project. Use coupon code SAVE10SS to take 10% off your order.
Second_Skin_Tri_Color__65247.1490223215.
Share this post
Link to post
Sign in to follow this
