3 15s box help...
1 hour ago, YukonXL04 said:
Which 15s? 10 cubes is about right on for 2 15s, but small for 3 15s.
Been told to stay around 9cuft (3cuft each) with the Contralto 15s and nothing is working out 🤣
Gotten so frustrated with it that just gave up...
And no computer now so can't download anything to help me figure out what I'm doing
*shrug*
Also don't know if should go with 2 8in aeroports like originally planned or just slot port it.
This is my 2nd attempt at a box, first one didn't work out...
*shrug*
I can get you some good numbers for a box. I'll look up the Crescendo specs and post numbers shortly. I prefer slot port myself.
Are you limited to 18" high?
Also... 42 wide will be tight for a slot port design. Probably want to go aero port if you're limited to that width. I also can't find woofer displacement #'s anywhere. Lmk
5 hours ago, DiBo said:
What 15's require 5ft³ each? Even zv5 and nsv4 15's with over 33mm of xmax only require 4.25 maximum. 5ft³ is too big for 15's.
Specs are 44w, 19.5h, and like to stay around 30d...
I've really wanted to do an aeroport box for awhile now but I can't get it to work out right on that app hahaha...beening looking at 2 8in ports...
I do believe 3-3.5cuft per sub is the magic number...
Subs will be 2 inverted, one in the box so sub displacement is 0.23...
54348282_255792728702975_188408614568853
Where I'm stuck now...
3 cubes sound pretty small for a 15. Most of the 15s I have used wanted between 4 and 5 cubes. But I'm also a big box guy too, cant stand a too small ported box
Fi, psi, DD... all want 3-5 for most of the 15s. I dont run sundown so I dont know.
05 TL build log SOLD
I talked to Crescendo audio today. They suggested 10ft³ with around 144in² of slot port. Less with aero. I can actually get a design with subs up Port back ( slot Port ran across the bottom).
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
