Mr.Angel Posted March 11, 2019 Report Share Posted March 11, 2019 What am I doing wrong? Trying to measure headunit thru an amp, Mono amp: MRV500 So track 1, I do the steps but the 40hz doesnt pop up on max volume, Only Thing I see is the distortion light pop up??? SAME With track 2, the 1khz or 40hz, doesnt pop up HOWEVER: I notice when I turn the gain up on the amp (testing to see) when measuring the headunit, The 40hz does pop up? Am i doing something wrong because going through the book steps, the only light that pops up is the distortion unless I turn the gain up then it turns on. I stick the red on the positive wire and the black on the amp ground wire So what I did was just ignore it and set my gains on for the subwoofer using Track 5 (40hz -10db), So the 40hz or 1khz the light didnt pop up from the 1st step of measuring the headunit, is this Okay to set my gains like this? I even turned the amp bass boost almsot all the way up bcus it wasnt hitting as hard The distortion light pops up on regular music so I don't know what I'm doing wrong Quote Link to comment Share on other sites More sharing options...
BassMunky Posted March 11, 2019 Report Share Posted March 11, 2019 Just send to me. Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Mr.Angel Posted March 11, 2019 Author Report Share Posted March 11, 2019 11 minutes ago, BassMunky said: Just send to me. Where?, and do you have any solutions? Quote Link to comment Share on other sites More sharing options...
reedal Posted March 12, 2019 Report Share Posted March 12, 2019 Are all of your filters on the HU and amp set to full pass as directed in the manual? Quote SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
Mr.Angel Posted March 12, 2019 Author Report Share Posted March 12, 2019 13 hours ago, reedal said: Are all of your filters on the HU and amp set to full pass as directed in the manual? the filter (bass, treble,) on HU is set to flat like on the middle bar, and the LP filter is set to max, so really I'm doing what the book says but the 40hz or 1khz doesnt pop up unless the gain on the amp is turned up Quote Link to comment Share on other sites More sharing options...
CstrokerV Posted March 12, 2019 Report Share Posted March 12, 2019 Which dd1 you have? If you are measuring the deck through the amp I don’t think you will get a signal until the. Dd1 sees enough Volts and if the amps all the way down it might not have enough Volts from the deck unplug the rcas and plug it in the dd1 and set it that way first then amp Quote my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
BassMunky Posted March 12, 2019 Report Share Posted March 12, 2019 Doing it wrong Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
