MyNameIsNoob Posted March 12, 2019 Report Share Posted March 12, 2019 With a 370 amp alternator, is there a need to run more than one 0g power wire connecting the alternator, 2 batteries under hood and the 2 secondary batteries in the cab of a truck? If you're using dual inputs on your amps, I'm wondering if using a second run of power wire will help get the juice from the alternator to the batteries more efficiently, or if it will be needless money spent? Link to comment Share on other sites More sharing options...
Hooplah Posted March 13, 2019 Report Share Posted March 13, 2019 5 hours ago, MyNameIsNoob said: With a 370 amp alternator, is there a need to run more than one 0g power wire connecting the alternator, 2 batteries under hood and the 2 secondary batteries in the cab of a truck? If you're using dual inputs on your amps, I'm wondering if using a second run of power wire will help get the juice from the alternator to the batteries more efficiently, or if it will be needless money spent? 0 gauge ofc is only rated at 300 amps dont have to run battery from front to back fir ground but it helps Link to comment Share on other sites More sharing options...
Joshdashef Posted March 13, 2019 Report Share Posted March 13, 2019 I'd say use two runs of 1/0 no need to bottle neck that beefy of an alt. SMD Tool Map (2022): https://www.stevemeadedesigns.com/board/topic/220267-smd-tool-map-2022/ My Port Size Calculator (in progress): https://www.stevemeadedesigns.com/board/topic/217087-port-size-calculator-in-progress/ Common Port Walls for a Slot Port: https://www.stevemeadedesigns.com/board/topic/217076-common-port-walls-why-it-matters-to-your-box/?tab=comments#comment-3240313 Link to comment Share on other sites More sharing options...
MyNameIsNoob Posted March 15, 2019 Author Report Share Posted March 15, 2019 Thanks yall, that's what I was thinking. Havent been able to find anything talking ab that, so I was curious what everyone else is doing. Makes sense to me Link to comment Share on other sites More sharing options...
CstrokerV Posted March 15, 2019 Report Share Posted March 15, 2019 In damores section there’s something about that somewhere in there I know I spelt the name wrong lol my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
Wishuponasub Posted March 15, 2019 Report Share Posted March 15, 2019 I'm fixing to be installing a 390 and I will be doing 2 runs just to be sure. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4 Link to comment Share on other sites More sharing options...
MyNameIsNoob Posted March 18, 2019 Author Report Share Posted March 18, 2019 On 3/15/2019 at 2:11 AM, CstrokerV said: In damores section there’s something about that somewhere in there I know I spelt the name wrong lol Not sure if I'm looking past it or using the wrong search words, but do you remember anything about the title or how long ago it was posted? Link to comment Share on other sites More sharing options...
